WAH7608: Command Line Interface or any other way to access all system settings
Himmler
Is there any way to access all system settings, like IMEI, fixed TTL and other features ?
#SP_Nov_2019
#SP_Nov_2019
Hi HimmlerFor IMEI check, you can check IMEI info in Monitor > LTE Modem Status.Would you like to take a look at our user guide? You can find many function usage in the below document.0
There is no any info about advanced settings in user guide.I want to change IMEI, not just check it.0
- 588 USG FLEX H Series
- 476 News and Release
