VMG1213 access devices on LAN from WAN
Janosik
Hi all,
I have a LAN with several devices.
One of them is a computer, running a webserver (WAMP).
Another one is a microcontroller (ESP32), running some home-automation.
Until a few weeks ago, I could acces both from anywhere (WAN-to-LAN-acces).
Then, I changed my ISP from T-com (Slovakia) to Orange (Slovakia) and my router from TP-Link to ZyXEL (VMG1213-B30B).
Now I can only acces the devices from LAN.
I think I configured the new router exactly the same as the old one
(In NAT section: added port-forwarding to appropriate LAN-IP).
I tried changing some other settings, but nothing worked.
So I contacted Orange (where I bought the router) to ask for help.
First, they tried to sell me a static IP-adres, which I didn't want.
Then they came up with something like 'unblocking the settings'.
Both solutions would cost me a monthly fee...
Now... my questions...
Besides the port-forwarding, do I need to do anything else on this router to acces LAN from WAN?
And:
And:
Isn't WAN-to-LAN-acces considered to be a 'basic function of a router'?
I mean... to me if feels like: "buying a TV, and then paying monthly for the remote control" ...
Thank you for your attention
Janosik.
#SP_Nov_2019
#SP_Nov_2019
@Janosik,Is the model name VMG1312-B30B? What is the firmware version you use now?
Can you share your not working configurations?From your description, I think you are using dynamic WAN IP address from your ISP.
How did you access your local devices from WAN before(via IP or a domain name address)? Do you use any DDNS service?1 -
Hi hummel,
The model is indeed: VMG1213-B30B.
Firmware: 1.00(AAVU.4)b4
What configuration do you want to see? At this moment I have reset the modem to factory, and connected back to internet, so it is "standard clean".
I am indeed using dynamic WAN IPfrom my ISP.
At first, I accessed the devices from an other computer in my LAN, but I could also acces them from ANY other computer (at my neighbor's or brother or on vacation or ...). In both cases, I would open a web-browser and enter my router's WAN IPv4.
A bit later I found a free DDNS server, so I used that.
Screen-shot of the router's status:
(I noticed Ethernet WAN is disabled; also: there is no IPv4 under WAN information)
.0
@Janosik,It looks like your ISP only assigns IPv6 IP address to your device.Maybe it is a clue for the problem you meet.Have you bind your IPv6 IP address with your free DDNS server?Do you think it is possible to ask for a IPv4 WAN IP address from your ISP for a test?1
Indeed I think I only got IPv6 from ISP for my router...
When I contacted them, they told me that there were no more (free) dynamic IPv4 available.They could only SELL me a static IPv4 !!!I think that is very strange...
Now... just to be sure: if the above is correct (only IPv6), then there is nothing I can do in the router configuration to solve this problem?
EDIT: I just had a look at my free ddns (noip.com), and it seems like it only works with IPv4.0 -
The web-server is a desktop which indeed has it's own IPv6, but I don't know how to access it either with or without port-forwarding.
The home-automation micro-controller is a little arduino-like board (ESP32) that doesn't seem to have an IPv6.
What do you mean by: "pass through the CPE's firewall"? How do I do that?0
- 243 Nebula Ideas
- 6.9K Security
- 786 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
