vpn between LTE6100 & USG40w
Hi. I trying to establish an IPSec IKE1 Site-to-site with Dynamic Peer VPN connection from LTE610 to USG40W
I'm sure that all settings on USG40W are right. No errors on USG - he doesn't see any attempts to connect from LTE6100. I have tried to make the same type connection between LTE6100 and Keneetic Giga III - same problem.
What did i do wrong on LTE6100?
@evgeshock
Does LTE6100 support VPN?? I searched the spec from google and it says LTE6100 only supports VPN passthrough which means it won't initiate the VPN connection by "itself".0 -
@evgeshock
After checking the user manual, it seems LTE6100 does support VPN function. I'm wondering that had you seen any vpn related log on both devices (USG40W<E6100)??0 -
Sure. Thank you/ There are no questions and problems when you try to establish VPN with device that doesn't support VPN function. Nothing to discuss
Unfortunately (and i wrote about it above) no logs about this connections: LTE doesn't even try to establish a connection. Or Internet provider blockes connections (LTE has "grey" IP - I called them, they said that no any blocking).
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
