Time restriction on additional WLAN?
AllTogether
Greetings!
I am looking for a wifi router which can make a second wireless network
and set a time restrictions for every weekday on it.
Could you tell me if it is possible withe the Zyxel routers?
If yes, please suggest routers models that I should look at.
Thanks much!
#Home_Router_Dec_2019
https://www.zyxel.com/support/download_landing/product/armor_z2_22.shtml?c=gb&l=en&pid=20160503102311&tab=User_s_Guide&pname=ARMOR%20Z2
ARMOR Z2 (NBG6817) has wireless scheduling feature. And it has powerful WiFi signal coverage (AC2600).
Hello TeemoThis sounds promising!Can I have two wireless networks with this routerand set the time schedule only for one of them?Thanks much for you help.0
ARMOR Z2 (NBG6817) can set one main SSID and three guest SSID per band (2.4GHz/5GHz). But wireless scheduling feature for whole band (2.4GHz or 5GHz), not able to use for only one SSID.
Maybe you can refer to Zyxel Multy Series.
It can set Internet time limits for devices by group.
https://homeforum.zyxel.com/discussion/196/how-to-set-up-the-parental-control-feature#latest1 -
Thanks TeemoHave a great day!1
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
