[NSA320] Install open SSL / Entware opkg command not found
Virrr
Virrr Posts: 2 image  Freshman Member
edited January 2020 in Personal Cloud Storage
I get a SSL error when trying to pull something from Github. Is seems I have to upgrade openssl. I tried slacker but it only has version 1.0.0 available.
I also have entware installed but when I use the command opkg I get an error:
-sh: opkg: command not found.
#NAS_Jan_2020
  • Mijzelf
    Mijzelf Posts: 3,066 image  Guru Member
    You have Entware-ng and ffp installed? Read the page about Entware-ng and ffp coexisting in the webpage of Entware-ng on your NAS.
    BTW, you are aware that this won't update the ssl from the firmware? Only the Entware-ng environment can use it.
  • Virrr
    Thanks for your reply! Does this mean the firmware is outdated and will cause more 'ssl related' problems?
  • Mijzelf
    Basically yes.
