how to find ip adress of my router ?
DAY_info
I must change an old router and find the parameters but i don't know the ip adress. 192.168.1.1 dosen't work.
#Home_Router_Jan_2020
If the dhcp server works, the 'default gateway' on the client is normally the router.
Hello @DAY_info,
you can try this to find out your default gateway = your routers IP:
https://www.youtube.com/watch?v=9XOuSog1HJE&t=3s
Try either http and https in front of the IP to access the router.
Greetings
- 441 Beta Program
- 292 Service & License
