FFMPEG not working on NSA325v2. Did I install it wrongly?
AleXSR700
Hi everyone,
I wanted to install ffmpeg, but it seems I am doing something wrong.
I ran slacker -Ui and then installed ffmpeg.
But I cannot run ffmpeg in shell. It is not being found.
I have ffp and entware-ng installed next to each other, if that matters.
<code>
sudo find . -print | grep -i 'ffmpeg*' ./ram_bin/usr/local/dmsf/binary/cgi-bin/ffmpeg-video-thumb.desc ./usr/local/dmsf/binary/cgi-bin/ffmpeg-video-thumb.desc ./usr/local/zy-pkgs/ffproot/ffp/funpkg/removed/ffmpeg-0.8.7-arm-1,reinstalled,202002 07_034542 ./usr/local/zy-pkgs/ffproot/ffp/funpkg/installed/ffmpeg-0.8.7-arm-1 ./usr/local/zy-pkgs/ffproot/ffp/funpkg/cache/s/ffmpeg-0.8.7-arm-1.txz ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2m4acommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2oggaudiocommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2opusaudiocommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.muxtomp4command.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demux2m4acommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demuxgenericcommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.muxtowebmcommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demux2mp3command.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demuxandconvert2ogg.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.extensiontoformatmap.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2aaccommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demux2aaccommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.muxtomkvcommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/themes/standard/org/jdownloader/im ages/logo/ffmpeg.png.license ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/themes/standard/org/jdownloader/im ages/logo/ffmpeg.png ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/logs/1580741728735_Mon, Feb 3, 202 0 14.55 +0000/org.jdownloader.controlling.ffmpeg.FFmpeg.log.0.lck ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/logs/1580741728735_Mon, Feb 3, 202 0 14.55 +0000/org.jdownloader.controlling.ffmpeg.FFmpeg.log.0 ./i-data/c7d796b4/.system/zy-pkgs/ffproot/ffp/funpkg/removed/ffmpeg-0.8.7-arm-1,rein stalled,20200207_034542 ./i-data/c7d796b4/.system/zy-pkgs/ffproot/ffp/funpkg/installed/ffmpeg-0.8.7-arm-1 ./i-data/c7d796b4/.system/zy-pkgs/ffproot/ffp/funpkg/cache/s/ffmpeg-0.8.7-arm-1.txz root@NSA325-v2-101:/#
</code>
Any ideas anyone?
Thank you for your help
#NAS_Feb_2020
<code>
</code>
Any ideas anyone?
#NAS_Feb_2020
P.S.: Does anybody know how you can tell slacker to ignore missing checksums.md5? It's preventing me from downloading from e.g. barmelej2.
It also happens with others and then simply aborts:
Updating package lists... fetch: rsync -q 'rsync://ffp.inreto.de/ffp/0.7/arm/packages/CHECKSUMS.md5' '/ffp/funpkg/cache/s' fetch: (cd '/ffp/funpkg/cache/mz'; wget -Nnv 'http://downloads.zyxel.nas-central.org/Users/Mijzelf/FFP-Stick/packages/0.7/arm/CHECKSUMS.md5') FATAL: mz: No CHECKSUMS.md5 Thanks for using UW Site Loader! root@NSA325-v2-101:/ffp/bin#0 -
I suppose you installed ffmpeg-0.8.7-arm-1.txz, which contains only libraries, and no executable. You could install ffmpeg-1.1.1-arm-2.txz instead, which also contains a binary.About the checksums.md5, you have to edit your /ffp/etc/funpkg/sites, and remove the dead links.
So your own link is dead? I get the same error from your server.
Also, I cannot select to install a different ffmpeg because there is none on any of the working servers
Okay, got it running now, thank you
However, the ffmpeg in your own repository does not include the libshine.so and therefor does not work. I had to install the br2 version.
For some reason jDownloader still claims that FFMPEG is missing
<div>ffmpeg version 0.10.2 Copyright (c) 2000-2012 the FFmpeg developers</div><div> built on Apr 2 2012 13:27:15 with gcc 4.5.4 20111110 (prerelease)</div><div> configuration: --prefix=/ffp --disable-static --enable-shared --enable-gpl --enable-nonfree --enable-small --disable-encoder=aac --disable-decoder=aac --disable-armv6 --disable-armv6t2 --disable-armvfp</div><div> libavutil 51. 35.100 / 51. 35.100</div><div> libavcodec 53. 61.100 / 53. 61.100</div><div> libavformat 53. 32.100 / 53. 32.100</div><div> libavdevice 53. 4.100 / 53. 4.100</div><div> libavfilter 2. 61.100 / 2. 61.100</div><div> libswscale 2. 1.100 / 2. 1.100</div><div> libswresample 0. 6.100 / 0. 6.100</div><div> libpostproc 52. 0.100 / 52. 0.100</div><div>Hyper fast Audio and Video encoder</div><div>usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...</div><div><br></div><div>Use -h to get full help or, even better, run 'man ffmpeg'</div><div>admin@NSA325-v2-101:~$</div>0 -
Okay, got ffmpeg up and running with your version. Had to install a few more things
ffmpeg-1.1.1-arm-2, x264-20130313-arm-1, twolame-0.3.13-arm-1, shine-20130313-arm-1, rtmpdump-2.3-arm-1, opus-1.0.2-arm-1, fdk_aac-20130313-arm-1, libass-0.10.1-arm-1, freetype-2.4.11-arm-1, fribidi-0.19.5-arm-1, fontconfig-2.10.91-arm-1
But jDownloader still won't work. Tried setting the path to '/ffp/bin/' but jDownloader just tells me that the new value could not be set.0 -
Don't know if my version is better than br2's. It's long ago that I created the package on request.And sorry, I have no idea how jDownloader expects to find ffmpeg.0
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
