VMG3625-T20A FTP Server Problem
med_cezir
I was looking for VDSL modem which has gigabit ethernet port and FTP server options. So I decided to bought VMG3625-T20A, but it's FTP protocol has problem. When uploading files which bigger than 4-5 mbyte everytimes FTP client programs(FileZilla, WinSCP etc) fails, connection lost or upload retries with unsuccess result.
I tried to format my USB dongle with FAT32,exFAT or NTFS result is same, also I tried to send files at active or passive FTP modes there was again no succes. I need help with this problem.
Thanks for all.
#SP_Mar_2020
Thanks for all.
#SP_Mar_2020
@med_cezir,
what account do you use to log in FTP?Where is the destination you upload your files?And what is the firmware version you are using?0 -
@med_cezir,I am a little bit confused.So what you mean is you have a FTP server which is connected behind the VMG3625-T20A?0
Hi @HummelFTP server is not behind of VMG3625-T20A, it is on the VMG3625-T20A. You can see settings below. I have described problem on first message. Server fails when upload bigger files then 4-5MB, you can try too with information which is on previous message.Thanks.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
