VMG3625-T20A FTP Server Problem
med_cezir
med_cezir Posts: 3 image  Freshman Member
edited March 2020 in Smart Home Product
I was looking for VDSL modem which has gigabit ethernet port and FTP server options. So I decided to bought VMG3625-T20A, but it's FTP protocol has problem. When uploading files which bigger than 4-5 mbyte everytimes FTP client programs(FileZilla, WinSCP etc) fails, connection lost or upload retries with unsuccess result.
I tried to format my USB dongle with FAT32,exFAT or NTFS result is same, also I tried to send files at active or passive FTP modes there was  again no succes. I need help with this problem.
Thanks for all.
#SP_Mar_2020
  • Hummel
    Hummel Posts: 212 image  Master Member
    edited March 2020
    @med_cezir,
    what account do you use to log in FTP?
    Where is the destination you upload your files?
    And what is the firmware version you are using?
  • med_cezir
    edited March 2020
    My ftp server info is like below;
    adres: -.dynu.net
    port:"2121"
    user: "test" , pass:"test1234"
    Current Firmware Version is: "V5.30(ABIE.5)G0"
  • Hummel
    @med_cezir,
    I am a little bit confused.
    So what you mean is you have a FTP server which is connected behind the VMG3625-T20A?
  • med_cezir
    FTP server is not behind of VMG3625-T20A, it is on the VMG3625-T20A. You can see settings below.  I have described problem on first message. Server fails when upload bigger files then 4-5MB, you can try too with information which is on previous message.
    Thanks.
