Zyxel WAH7608 - shut down itself
tomas11
tomas11 Posts: 1 image  Freshman Member
edited April 2020 in Smart Home Product
I both 3 days ago this modem and facing issues.
Zyxel shut down itself for no reason and I am not able to find why....
If I want to boot it on again battery needs to be removed and put back. Without this I am not able to power it on.
Please help as it is urgent case.
Thanks for reply.
#SP_Apr_2020
  • Mia
    Mia Posts: 16 image  Freshman Member
    Do you check the battery charge in low so WAH7608 shut down itself? It's not recommend low battery be charging by laptop USB and use it in low battery and at the same time. Because laptop USB may not stable enough for charging, it might cause battery over-discharge that the device battery capacity is empty caused by WAH7608 shut down itself.
