How to setup port forwarding usg20 Port 3727 to a terminal server 160.82.13.212
Billy_Britt
Trying to setup port forwarding to my terminal server. IP address 160.82.13.212
From outside my office I am trying to use port 3726 to go to my terminal server for RDP(3389 port)
@Billy_Britt,
Regarding to your request, you need to create profiles of Security policy and NAT rule to allow outside clients can access to server.
Go to Configuration>Network>NAT
Go to Security policy>security control
Charlie0 -
I would guess your WAN IP address is 160.82.13.212 and you want to NAT to a LAN IP for RDP on like 192.168.0.xxx
If your WAN IP f changes for the NAT rule Original IP you can make a address rule with address type INTERFACE IP with interface WAN1
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
