Zyxel P-870HN-53b forgot admin password
Leuko
I have problem with Zyxel P-870HN-53b, whtch I have set a port forwarding QoS etc.
Previous network administrator set a password but he not tell me.
Firmware maybe : V1.12(AAEZ.0)Can you give me a assistant please?
Thank you
Thank you
You are the owner of the Zyxel P-870HN-53b, right? And you have the device on hand with you, right? If yes, all you have to do is do a hard reset to your Zyxel P-870HN-53b and your admin password will go back to the default password.0
uhmmm... It wil be a problem. I dont know, wchit ports are set on router, port forwarding etc.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
