How to setup port forwarding usg20 Port 3727 to a terminal server 160.82.13.212
Billy_Britt
Billy_Britt Posts: 1 image  Freshman Member
edited April 2021 in Security
Trying to setup port forwarding to my terminal server. IP address 160.82.13.212
From outside my office I am trying to use port 3726   to go to my terminal server for RDP(3389 port)
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited March 2018
    @Billy_Britt,
    Regarding to your request, you need to create profiles of Security policy and NAT rule to allow outside clients can access to server.
    Go to Configuration>Network>NAT
    Go to Security policy>security control
    Charlie
    PeterUK Posts: 4,411 image  Guru Member
    I would guess your WAN IP address is 160.82.13.212 and you want to NAT to a LAN IP for RDP on like 192.168.0.xxx
    If your WAN IP f changes for the NAT rule Original IP you can make a address rule with address type INTERFACE IP with interface WAN1
