PLEX on NAS542
The< zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/ > failed
That is normal. You can only ping domains (or IP addresses).
In some way it's a pity you can ping zyxel.diskstation.eu. That means it's reachable for your NAS, which rules out the simple solutions.
Next step is the logfile. You can find it in /i-data/sysvol/.system/zy-pkgs/zypkg.log. It's huge. Search for error messages in the neighborhood of the string 'zyxel.diskstation.eu'.
The RESET was not succesfull either. Still can't find the MetaRepository after refreshing the App center. There are still no failed messages in Log report.0
Enable the ssh server on your NAS, and use WinSCP to search for the logfile.
Hy @Mijzelf
I'd like to thank you for your all support and time! It was understandable at the first time what to do. In spite of this, I still can't go through to this step.
The SSH service was accept but the /i-data/sysvol/.system/zy-pkgs/zypkg.log. patch is does not exist.
I set up the patch to the SYS log server but I still can't find log file in this folder.
I am so sorry to bother you many times, I'm pretty sure that I did something wrong.
Files (and directories) starting with a . are considered 'hidden' in Linux. So you have to tell WinScp to show hidden files:
Hi All,
I have a lot of problem for reproduce the sound DTS 5.1 in my NAS542 with plex. Some movies run but another ones no. How could be fixed?0 -
I think you'd rather ask this in a Plex forum.
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
