Disable dual transmission
                    Callie
                    Hi - I have a Post Office router, it transmits  WIFI on two channels and I want minimal WIFI so would rather disable one but can't find how to do it.  There are some settings that seem to allow me to select 1 channel but it doesn't make a difference.  Can anyone point me in the right direction please? Thank you!
            How do you know / What's the "two" channels the Router uses?
 You can check "channel width" settings and set 20 MHz as the value.0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
