How can I use the SFP Ports on a GS1900-24?
I have a GS1900-24 and am utilizing the RJ45 ports as normal but I also have a 4 port Mikrotik 10gbe switch and pass one of those ports into the GS1900-24 switch but there is no LED showing connection and also shows no connection on the monitor. I have tried 4 different cables, copper & fibre but nothing shows as connected? is there something I cannot find that needs to be enabled or am I understanding it wrong?
Best Answers
Hi mbc0
You can try to fix the speed and duplex to 1G for both ports then I think it can link up.
Friendly remind that this forum is for home device, for GS1900 series, you can ask question in our biz forum.
https://businessforum.zyxel.com/categories/switch
Best regards,
Zyxel_Derrick
Thank you for your reply, I mis-understood, I thought home forum was for home users not for home devices, sorry I just bought one of these for my home.0
Hi mbc0
Best regards,
Zyxel_Derrick
- 441 Beta Program
- 292 Service & License
