VMG8825-T50 - Parental controls not working
mtn
The following simply does not work. The device is still connected to the internet despite this setup. How do I fix this? I've also tried if from the Security menu option, also not working.
#SP_May_2020
V5.50(ABPY.0)b12_20190730
@mtn,Looks like not the same firmware in my VMG8825-T50K.The firmware version of mine is ABOM not ABPY and the WebGUI is also a little bit different. Is the model name of your router called VMG8825-T50K? Looks like your are using a customized firmware. My suggestion is to get your ISP's support for it.I have tested it with my VMG8825-T50K and I don't met the problem. The parental control rule work correctly.0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 491 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
