BUG antivirus corrupt ods xlsx
In the past the same happen with 4.25 Version with pdf file, now with xls and ods, is normal?
@DanZyw
I tested it with ods file locally without any issue.
Therefor, could you private message the xlsx and ods file to me for checking further.
Charlie0 -
I have same problem @DanZyw .
I have a USG 310, firmware version V4.31(AAPJ.0).
While UTM Antivirus serivice is active (security policy "LAN_Outgoing" rule), many of xlsx files attached to emails are corrupted, even if they are compressed into a signle .zip file.
If I disable UTM Antivirus service and retrieve the same e-mail again (for example from webmail service), the same files are all ok. Same issue with POP3/IMAP mail clients.
I note the same issue also with files downloaded from FTP sites, they often are corrupded while UTM Antivirus service is enabled.
Any help will be appreciated.
Sorry for my bad english.0 -
Hi @ Pavanix
We have fixed similar issue in 4.33 FCS firmware.
You can send me your configuration and test file by private message, I can help to verify it first.0
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
