Problem zyxel VMG8823-B50B
Davide90
Goodmorning everyone!! my modem for about 6 months has been losing the connection for a few seconds or minutes and then recovering the technician says that it has not detected any problems since these things happened on the connected devices screen a device called local host appears (what would it be ??) could it come from that? or from a change of ip or static ip? can you disable this device? as for modem updates .. does it do them automatically or do you have to do them manually?
thanks in advance and sorry for my keyboard english!
Do you know what the firmware version you are using now?
Login WebGUI and then you should be able to see the Firmware Version.As I know, your ISP should be able to do firmware upgrade for you remotely or you should upgrade firmware manually via WebGUI.If you want to manually upgrade firmware, first of all, you need to download the firmware from Zyxel's official website and that's why I ask you the firmware version.0 -
Scrivi il tuo commento 0 -
this also appears to me among the connected devices !! What could it be? influences?0 -
This is wind/infostrada (now wind-tre) branded firmware.
They released just one upgrade when they realized it was "easy" for the user to get voip credentials.
You can't upgrade via web interface, the firmware id/model is "different" from the standard one.0 -
I don't know what to say about disconnections often and a technician will arrive in a few days
riguardo il firmware la wind dice che va bene cosìbut instead the local host that I see between the devices what is it? you can take it off !!! or is it useful?0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
