VMG3925-B10B Firmware update
capsndave
I would like to update the firmware on my VMG3925-B10B router. I followed the instructions however the Firmware selection in the Maintenance menu is just not there in the list. What's going on?
#SP_May_2020
@capsndave,Can you take a screenshot to show why you can't find the way to upgrade the firmware? The firmware upgrade page should be at Maintenance > Firmware Upgrade.You should download the firmware first from Zyxel's FTP. Unzip the zip file and select the .bin file to upgrade. Please make sure the firmware ID is the same, otherwise, it won't allow you to upgrade firmware. The latest version I can see is 5.13(AAVF.13)C0.
ftp://ftp2.zyxel.com/VMG3925-B10B/firmware/VMG3925-B10B_5.13(AAVF.13)C0.zip
Hi Many thanks for your response. That the firmware I downloaded intending to upload to the router. It seems a little crazy but the firmware option is missing from the list as per the image attached. - Hope you can make it out.
What user account do you use to log in? Have you tried admin account?0
Btw. My current firmware version is V5.11(AAVF.3)C00
Thanks Hummel. That's a good point. The're are 2 accounts on the router 'user' and 'admin'. That might be the root of my problem. B/w D1
justy press the reset button on the back while its on then turn it off and on0
The latest firmware seems to be unified version for b10, b10b and b10c versions V5.13(AAVF18)C0 and it comes with different looking UI and has a feature like concurrent WAN missing. Is it possible to bring this feature back or have instructions to work around this?
How can I load the zip file using ftp (what username and password)?
br
Matti
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
