VMG1312-B10D Remote management?.
rahulsaha123
I have Zyxel router VMG1312-B10D firmware V5.13(AAXA.7)C0 . I can't manage it remotely
I of course enable the remote management, I tried Http, Https tried to change the port - nothing.
thanks
rahulsaha
thanks
rahulsaha
#SP_May_2020
Do you mean you enable http and https in remote management but you are not able to access it from the Internet?
Can you share your settings and test steps that how you try to access VMG1312-B10D remotely? It would be better if you can share the information that how you connect VMG1312-B10D (Topology) to the Internet for a reference.
I'm testing a G1 and G5 Armor Zyxel router. Is there a central software platform available when you can manage all your routers from one place that has an API and using such protocols as YANG/NETCONF ?0 -
Hello @JimmyA
I don't know if these Zyxel products can manage these routers, as I don't work for Zyxel, but they might https://www.zyxel.com/uk/en/products_services/smb-network_management.shtml?t=c
Depending on which of the Faults, Configuration, Accounting, Performance and Security (FCAPS) functionality you want, some products like Paessler PRTG might be useful https://www.paessler.com/prtg?msclkid=a41d10bb3dbc15f809d370a5fd5bbe25&utm_source=bing&utm_medium=cpc&utm_campaign=GBR_EN_Search-Brand_phrase_2&utm_term=paessler%20network&utm_content=paessler-network as it can do SNMP and Syslog and Ping to check uptime.
Kind regards, Tony0
- 441 Beta Program
- 292 Service & License
