I have 2 Multy x
Schdie
I have 2 Multy x - can i make one wlan when i Connect both with the cable or do i have to make 2 different wlan?
#Multy_May_2020
#Multy_May_2020
You can create a Multy Site with two Multy node in it. App will tell you to set a SSID.
After the setup, you will have one SSID and broadcast on two Multy nodes.
However, you have cables on both nodes, so you can refer to my other comment to create a Multy Site with Ethernet cable.
https://homeforum.zyxel.com/discussion/3757/two-multy-plus#latest
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
