Change Wan Priority on VMG8825-B50B
Runner73
Runner73 Posts: 17  Freshman Member
edited June 2020 in Smart Home Product
Hi all,
i need to configure a VMG8825-B50B [ Firmware VMG8825-B50B_5.13(ABNY.4)C0 ] for VDSL bridge mode without lost VOIP connectivity.
Router B is a router that has his WAN interface connected on the Eth4 port 4 of the Zyxel
I'm testing this configuration:
- Broadband VDSL in ptm bridge mode on the zyxel
- Group interface modified to associate Eth4 to VDSL on the Zyxel
- EtherWAN in DHCP mode as default gateway and NAT on the Zyxel
- Voip service mapped on EthWAN
If I start the zyxel and attached the router B all works fine and I have public ip address on the wan of the router B. When I connect the EthWAN I lost VDSL connection because the Zyxel attempt to use internet on the WAN.
Please can you explain me how I can change the priority of the WAN connection so I don't loos VDSL and mantain voip connection ?
Regards
#SP_May_2020
  • Hummel
    Hummel Posts: 212  Master Member
    If you use Interface Grouping to associate ETH4 to VDSL WAN Interface, then your router should not try to use the other WAN interface. Can you please check your relevant settings again? Please take screenshots of your WAN Interface settings, Interface Grouping settings and post them for a reference.
  • Runner73
    thanks for you response. I checked the settings, but seems all ok.
    Below the screenshot.
    Regards
  • Runner73
    And this is the log.
    Bold line is when I attach the lan cable on the EthWAN port of the Zyxle
    3 Jan 1 01:02:21 user notice system zcmdModuleCfg: System: Wan interface ETHWAN connection ready
    4 Jan 1 00:02:20 kern info dhcpc udhcpc: dhcpMsgSend: msgType[-2147483432]
    5 Jan 1 00:02:20 kern info dhcpc udhcpc: Lease of 192.168.4.7 obtained, lease time 315413119
    6 Jan 1 00:02:20 kern debug dhcpc udhcpc: Sending select for 192.168.4.7...
    7 Jan 1 00:02:20 kern debug dhcpc udhcpc: Sending discover...
    8 Jan 1 00:02:19 kern notice dhcpc udhcpc:
    9 Jan 1 00:02:19 kern notice dhcpc udhcpc: Attached to parameter name shared memory
    10 Jan 1 00:02:19 kern notice dhcpc udhcpc: Attached to object name shared memory
    11 Jan 1 00:02:19 kern notice dhcpc udhcpc: Attached to schema shared memory
    12 Jan 1 00:02:19 kern info dhcpc udhcpc: udhcp client (v0.9.8) started
    13 Jan 1 00:02:18 user info xdsl esmd: xDSL: XTM link down.
    14 Jan 1 00:00:55 user info xdsl esmd: xDSL: link up, Connection Type: PTM, Speed: RX:178343 / TX:21600 (Kbps)
  • Hummel
    edited May 2020
    I also don't see any problem from your settings.
    LAN4 and VDSL are grouped together which means your router connects to LAN4 should go through VDSL WAN interface not Ethernet WAN interface. But according to your description, you think it goes through Ethernet WAN when you connect ETH WAN to Internet. It sounds strange.
    And from your logs, xDSL link was down first (xDSL: XTM link down) and then your EthWAN got the connection.(Wan interface ETHWAN connection ready) Any idea why the xDSL link goes down when you connect EthWAN? Can you show your topology to let us know how you connect VMG8825 to VDSL modem and EthWAN at the same time?
  • Runner73
    This is the topology of my network
