zyxel vmg 1312 b10d disconnects frequently.
Senthil
I bought zyxel vgm 1312 b10d last week and it disconnects frequently. Also the signal is very weak in my bedroom. I have to restart the modem at least once a day . I am thinking of buying a wifi range extender. can you suggest me a compatible model?
Hi Senthil
If the signal is weak in your room already, it's a good decision to buy to Wi-Fi extender. So far we did not receive too many IOP issues from the extender side. For a safe option, I would suggest please consult with your ISP (also they have more knowledge about which extender is available in your area/country). After you tried one, if you have further issues, then we discuss it.
Hi @SenthilI have found the TP-Link RE300 range extender to be compatible with the VMG1312-B10D see https://www.tp-link.com/uk/home-networking/range-extender/re300/Merry Christmas and Happy New Year.Tony
- 588 USG FLEX H Series
- 477 News and Release
