Zyxel VMG3925
Anonymous
About the wireless guest. Is it normal that when "Guest WLAN" is active devices on that wireless network can't be contacted from outside even it they are on DMZ or port forwarding is set?
Hi Sir
I am not sure about your meaning. DMZ used for a LAN client reserved for WAN (internet side) visit can access. And the Guest WLAN is already in LAN side, do you mean if Guest Wifi client can be set as a DMZ host?0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
