Zyxel VMG3925-B10B Setup for Sky Fibre
Kev1234
Hi everyone, would really appreciate some help in setting up my newly acquired modem please.
I have Sky Fibre broadband (up to 24MB) and i'm trying to completely do away with the Sky Q router, as it's rubbish. I have purchased a Zyxel VMG3925-B10B after reading some rave reviews and my intent is to use it in Bridge mode with an Asus RT-AC66U_B1 as the WAP. I've turned it into bridge mode for both the ADSL and VDSL connections in the GUI, i've also turned off the IP4 and IP6 firewalls. Before and after doing these settings, the internet light on the modem is a solid read, not sure if that's to be expected or not? I've tried connecting the Asus router to it WAN port to WAN port, plus LAN on the Zyxel to WAN on the Asus, not sure which way round it should be but neither works. I've flashed my Asus router with the Merlin firmware and specified a generic sky email in the Option 61 field, so I believe that's setup as it should be.
I'm quite technical but not really when it comes to networking, could someone please help as i'm desperate to get this new combination up and running as homeworking has become very difficult for my wife and I while using the Sky Q router. The main issue we had was that internet was fine while only one person was using it, as soon as another request comes in for bandwidth it seems to cripple the other connection.
Any help would be really appreciated!
Thanks,
Thanks,
Hi Kev1234
It's normal if Internet LED light up in red when you set VMG3925-B10C in bridge mode. The LED used to display if VMG3925 default gateway has IP or not. Since we are using bridge mode, no IP thus internet light up in red.
Then, if you mentioned only one person can use the internet connection, it means traffic can passthrough VMG3925-B10C to access the internet. I would like to ask if both your wife and you set up the same PPPoE account with different laptops? Please let ASUS router mainly control WAN access, and other clients received ASUS DHCP LAN side IP.0
- 588 USG FLEX H Series
- 477 News and Release
