The GS1900-24HP can power ubiquiti access point and other stuff (802.3af/A PoE)?
hello everyone, I would like to know if the switch in question (GS1900-24HP-EU0101F) is able to power the following ubiquiti products via PoE:
UAP-AC-M (802.3af/A)
UAP-AC-LITE (802.3af/A)
Ubiquiti Unifi Controller, Cloud Key (Power Method: PoE 48V 802.3af or Passive PoE (Pairs 4, 5+; 7, 8 Return) or Micro-USB 5V
Power Supply: 802.3af PoE or Micro-USB 5V, Minimum 1A
Max. Power Consumption: 5W)
Thanks for a possible reply.
#Biz_July_2020
#Biz_July_2020
Hi @uiblog.it
GS1900-24HP follows the PoE standard which can support 802.3at/af and uses wire 1.2.3.6.
Therefore, if these two products also follow the standard and use wire 1.2.3.6 then it can be powered up by our switch.
You can check the further detail on GS1900 series datasheet
https://www.zyxel.com/support/download_landing/product/gs1900_series_9.shtml?c=gb&l=en&pid=20130521174809&tab=Datasheet&pname=GS1900%20Series
Friendly remind that this forum is for home devices, for our business model devices such as GS1900 series, you may seek our biz forum. https://businessforum.zyxel.com/
Thanks!
Best regards,
Zyxel_Derrick0 -
I can confirm that the GS1900-24HP can successfully power a compatible UniFi access point.We've been using a GS1900-24HP at our office for over a year now,in combination with a UniFi UAP-AC-LR access point, and it works just fine.Be careful though - some of the older UniFi access points, such as theUnifi UAP, and UAP-LR access points use passive POE, and won't workwithout a power injector.As long as your devices use either 802.3af or 802.3at, you should be good to go.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
