Does Multy X AC3000 support Ethernet Backhaul?
shayanitalia
I want to know if Ethernet Backhaul Setup is supported on the Multy X AC3000 system and what the maximum Wifi Speed is on the 5 GHz channel across a 1gbps Internet connection. So basically if I connect a CAT 7 cable from my main Multy X Model (GIGA LAN OUTPUT) to my Multy X WAN port, will the ethernet backhaul system work by giving a much more rock solid connection.
#Multy_June_2020
#Multy_June_2020
Dear Sir,
Multy X has a dedicated band for backhaul connection, and the maximum rate is 1733Mbps.
However, 1733Mbps is a theory rate, Actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
Multy X Support Ethernet backhaul connection, please refer to the link.
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017839&lang=EN
The Ethernet backhaul will provide much stable connection for your Extender Multy.
Best Regards,
Eric0 -
This doesn’t answer my question:
1. does Multy super Ethernet backhaul?
2. What is the fastest Wi-Fi speed one can get (not wireless backhaul) on the 5Ghz channel across a 1gbps connection!
Please READ before you answer.
thanks0 -
Maybe you should read the answer? I see the answer on both questions.
1. Yes
2. 866Mbps0
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
