Zyxel Multy X and BT Smart Hub 1
AndyDo
Hi, I'm hoping the answer is yes from the bits I've picked up around the forum, but I wanted to check that the Multy X and Multy Mini will 'play nicely' with the BT Smart Hub 1 (Home Hub 6 I think). Other systems I've looked at seem to have requirements for the router which this hub can't satisfy (or can but require far more knowledge than I have). Thanks, Andy
Not really a confirms answer, sorry but...My understanding is that you need to put the ISP device into modem mode, which i can from Virgin Media but unsure about BT Hub. I myself was going to switch to BT in November (they now have 1GB in my area so can compete with Virgin).
So I will be interested to see what you find out.
Good luck finding out.
T0 -
Thanks, if I find out (and it doesn't require me to do a degree in Networking) I'll post back!1
- 243 Nebula Ideas
- 6.8K Security
- 782 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
