[NEBULA] Enable SIP
@JorisK
Because we have other customers ask about SIP ALG, and the good new is now we are working on discussing this feature internally, so I would like to clarify if your request is SIP server or SIP ALG? I would like to help to transfer this to internal.
I have a issue where a customer have 15 ip phones that need receive incoming calls from internet. This way I need to create a rule permitting this incoming connections, but I don't have 15 public IP address do NAT 1:10
Hi @ZeRicardo
Welcome to Nebula Forum.
We saw you created a ticket regarding this question through our technical support channel, we will reply you through ticket. After the case is clarified We'll update once more here in the post.
Hi @JorisK
For common VOIP solutions, SIP ALG is a necessary feature if you need to make calls from inside your local network to phones across the Internet.
Calls across your own private networks should work even if you have a SIP server on the public network.
I configure ALG directly on SSH session and all works fine, but if the device reboot is needed reconfigure manually. Is important to add this feature on NCC0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
