NBG6515
deneroydon
If I mount USB disk connected to NBG6515 router on Windows PC as a remote disk it says it has FAT32 file system. Which is not very convenient because I am unable to upload large files due to FAT32 limitations.
Is it possible to change this behavior?
Thanks.
https://bestpornwebsites.pro/
Thanks.
hot xxx sites is the latest list of top free porn websites
Hi @deneroydon ,The file-sharing feature on your NBG supports NTFS, FAT, and FAT32 file systems. You can use the computer to format the USB to the file system you want and put the files in it.You can also refer to the user guide page 147 for detail. Here is the link to download the user guide.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
