What does Green Solid LED mean?
Edison
Edison Posts: 2 image  Freshman Member
I pressed the reset button for 5 seconds and the LED turn to green, then the device  fixed and no more respond.
  • Zyxel_Eric
    Zyxel_Eric Posts: 279 image  Zyxel Employee
    First Answer First Comment
    What is your device that had the green LED on after pressing the reset button?
    Please provide the model name of your device.
  • Edison
    Multy U (WSR30)
  • Zyxel_Eric
    edited September 2020
    Dear Sir,
    When you pressed the reset button while the Multy was booting up, the Multy would into the Boot mode.
    Please reboot the Multy U again without pressing the reset button.
    If you would like to reset your Multy U, please pressing the reset button when it glows blue, red, or purple(Pink/Blue).
    Best Regards,
    Eric
  • snackamac
    snackamac Posts: 1 image  Freshman Member
    hi i have the same issue with a WSR30 it is stuck in "green led" when restarting it is yellow but then solid green
    any help to resolve this most welcome
  • Hill
    Hill Posts: 156 image  Master Member
    Do you try to reset the device, does the symptom still the same?
