What does Green Solid LED mean?
Edison
Posts: 2 Freshman Member
I pressed the reset button for 5 seconds and the LED turn to green, then the device fixed and no more respond.
What is your device that had the green LED on after pressing the reset button?
Please provide the model name of your device.
Multy U (WSR30)0
Dear Sir,
When you pressed the reset button while the Multy was booting up, the Multy would into the Boot mode.
Please reboot the Multy U again without pressing the reset button.
If you would like to reset your Multy U, please pressing the reset button when it glows blue, red, or purple(Pink/Blue).
Best Regards,
Eric
hi i have the same issue with a WSR30 it is stuck in "green led" when restarting it is yellow but then solid green
any help to resolve this most welcome
Do you try to reset the device, does the symptom still the same?
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 74 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 199 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
