I cant upgrade vmg3312-t20a
Orhun
I bought this yesterday. Firmware version is V5.30(ABFX.5)G0. I couldnt find anything about that G but website has an update named V5.30(ABFX.5)C0. First what is the difference and do i need to upgrade,second i tried to upgrade but it says Image uploading failed. You may press 'Cancel' to upload another firmware image file, or press 'OK' to reboot to recover normal operation.
Edit: My ping in games increased after started using this and the one i was using very old . Any reason for that ?
It is not allowed to upgrade fw from G0 to C0 because they are different firmware version.You can only upgrade from G0 firmware to G0 firmware.
C0 firmware is a generic version.
G0 firmware is a customized version firmware. If you need a newer version, you need to check it with your ISP who is using this version to get the latest version.
2
2
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
