What is the procedure to permanently turn off 5 GHz Wi-Fi in VMG3625-T20A?
kturkay
I have 2 children at home. and I don't want 5G. because of you know the radiation. When I press button of WPS both 5G and 2G is activating. I want only 2G and permanently disable 5G.
I found a similar question for a different model. however it does not an answer for "VMG3625-T20A"
no solution ?
You can check page 147 in the User Guide.
Select Band to 5G and then select Disable for Wireless.
ftp://ftp2.zyxel.com/VMG3625-T20A/user_guide/VMG3625-T20A_V5.13_5.50.pdf0 -
-1
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
