How do you block ping on VMG8825-T50 router?
Lexyz
I've tried using a firewall rule to ignore external ping requests but i get still responses.
Security > firewall > access control
rule: IPv4 / ICMP / DROP / WAN to ROUTER (or wan to lan)
Thanks for your help
It is possible that it's disabled by your ISP. What is your firmware version?Can't you ask your ISP to help you to set it up to disable the ping for WAN side?If you read the Note in Firewall page, you should see that even you set the security level to High, some services are still accessible.0
You can find it in the user guide.
ftp://ftp2.zyxel.com/VMG8825-T50K/user_guide/VMG8825-T50K_V5.13_5.50.pdfPage 345, Chapter 35 Remote Management
Thanks for your reply Hummel. Unfortunately the Remote Management option is not available under the Maintenance section. Could it be that it's disabled by my ISP? (i got the router from them). Is it not possible to use a firewall rule to achieve the same result?
Thanks for your help Hummel. My ISP confirmed ping i required for remote assistance and check the quality of connections
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
