NAS326: Apache Web Server?
Emerald Dragon
Emerald Dragon Posts: 120 image  Ally Member
Is it possible to run an Apache web server with database on NAS326?
«1
  • Mijzelf
    Mijzelf Posts: 3,051 image  Guru Member
    What is your goal? The NAS runs Apache, which serves the webinterface, and if you install the MySQL package, it alse runs a database.
  • Emerald Dragon
    I am trying to run CMS on it.
  • Mijzelf
    Ah right. In that case stock Apache won't work, as it lacks some modules (Only the modules needed for the firmware are included), and it's outdated.
    You can install Entware, (via MetaRepository) which has an up to date Apache, including a ton of modules, and MariaDB.
    But you'll have to fiddle with ports, as running 2 Apaches is not default.
  • Emerald Dragon
    How do I get Entware? Because I do not see that on the Apps List.
  • Mijzelf
    You have to install MetaRepository first. Scroll down for instructions.
    Or you can install Entware manually, following this instructions.
  • Emerald Dragon
    Thanks Mijzelf. The instruction is a little confusing. Especially at step 2.
  • Mijzelf
    Which instruction? For MetaRepository or for Entware?
  • Emerald Dragon
    Yes, the one you just posted above, I tried to follow it. But it is confusing for me.
  • Mijzelf
    I posted 2 instructions, one for MetaRepository, and one for Entware. Both have a step 2.
  • mackjone
    mackjone Posts: 1 image  Freshman Member
    Is it conceivable to run an Apache web worker with information base
    vpn black friday 2020
