How to find USB share in Windows10.
Zyxel_Support_CPE
Posts: 188 Zyxel Employee
If you want to access a hard drive or flash drive to USB on the router, but the connection isn’t successful when using the system win10. Please try to enable the SMB1.0 in the win10 first.
Step 1: Go to the Win10 Control Panel to set the SMB1.0 Feature- Control Panel -> All Control Panel Items -> Programs and Feature
- Click “Turn Windows features on or off”.
- Enable “SMB 1.0/CIFS File Sharing Support”
Step 2: Go to Windows Start and then search “network” programs. After find it, double click “netowork”
If lan IP of your device is 192.168.1.1, please type \\192.168.1.1 as followings. Then type username/password if it’s need.
After that, access to the drive is successful.
Jul 10, 2019 — How to import files from USB flash drive to Windows 10 ... Quick tip: If you get a toast notification, click it and select the Open folder to view files ...0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 98 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 975 Nebula FAQ
- 426 Security FAQ
- 238 Switch FAQ
- 212 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
