cannot connect to router control panel
router problems
router problems Posts: 2  Freshman Member
Fourth Anniversary
zyxel VMG3625-T20A. I cannot connect to the control panel and ive tried admin 1234, admin admin, user 1234, administrator 1234 and ive reset the router but it wont let me connect to the control panel.
Am i doing something wrong?
  • Hummel
    Hummel Posts: 212  Master Member
    edited December 2020
    Do you know what the current firmware you are using now?
    I think you should check the back label for the login information.
  • router problems
    Fourth Anniversary
    oh ok, didnt know they had their own password on the back. Im used to having the default passwords :)
