DHCP Settings from the CLI and/or an API?
Peter Tselios
Peter Tselios Posts: 22 image  Freshman Member
I have a VMG1312-B10D VDSL Router. Router's firmware is the V5.13(AAXA.5)C0
I haven't changed a lot in the device, so, I didn't need to access the CLI. Now, it's time to start some more advance configuration.
The first thing I need is to modify it's DHCP settings from settings that are only via the CLI.
But by CLI has only the following commands:
        . : [ [[ alias bg break cd chdir command continue echo eval exec
        exit export false fg getopts hash help jobs kill let local printf
        pwd read readonly return set shift source test times trap true
        type ulimit umask unalias unset wait
So, how do I access the router's commands?
  • Hummel
    Hummel Posts: 212 image  Master Member
    Normally, CLI commands are used for debugging usage,
    If you want to configure DHCP settings, it is suggested to change the settings via GUI.
  • Peter Tselios
    The settings on the gui are not very helpful.
    For example, I don't see anywhere settings for next server, or delay or ... or ...
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Peter Tselios
    There is a user guide for the VMG1312-B10D available at ftp://ftp.zyxel.com/VMG1312-B10D/user_guide/ which should give you some help.
    It says:
    and you change the setting on the LAN Setup page of the GUI.
    I hope that this helps. Merry Christmas and a Happy New Year.
    Tony
  • tonygibbs16
    Hi @Peter Tselios
    To get to LAN Setup in the GUI, you have you look under Network Setting and then Home Network.
    You will then get the following screen.
    I hope that this helps. Merry Christmas and a Happy New Year,
    Tony
  • tonygibbs16
    Hi @Peter Tselios
    Here is another extract from the user guide that might help you.
    Tony
  • tonygibbs16
    Hi @Peter Tselios
    Last manual extract for you that might help:
    Tony
