How to set up vmg router with Engenius enh500 as a Access Point
Bear33
Bear33 Posts: 1 image  Freshman Member
edited October 2019 in Smart Home Product
I received a Engenius enh500 as a gift and I'm not sure how to get it connected to a vmg router.  I would like to know what settings I need to change on the router to make it work. I guess I'm  just not computer savvy enough to get it done.  THANKS
#SP_Oct_2019
  • Hummel
    Hummel Posts: 212 image  Master Member
    @Bear33,
    My suggestion is to find the user guide or installation document of ENH500 from Engenius's website first. I believe the documents will teach you how to make it work.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @Bear33
    If you wanted to use the ENH300 as an outdoor access point, then it could be connected to one of the LAN Ethernet ports of a VMG router, but it might need some expertise to do it.
    I hope that this is helpful.
    Merry Christmas and Happy New Year.
    Tony
