Jdownloader installation
tomtom_38
tomtom_38 Posts: 9 image  Freshman Member
First Comment Eighth Anniversary
I had to set up my system again and installed jdownloader and java
my start scrpit is always deleted from / etc / init d.
Where is the right place for it and have I to define a user?
I use an 325v2 with ffp
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    In that case your start script should be in /ffp/start/
  • tomtom_38
     I do it and I copy that file in /ffp/bin/ too
    This message apears if I log in  (ssh)
    Could not chdir to home directory /ffp/home/root: No such file or director
    I recreate the folder but after three restarts the root folder  doesn t exits anymore
