VMG3625-T50B ISP in Slovakia AnnexB unable to connect to internet
Rudolf Torvenyi
hello,
I have a new VMG3625-T50B router. The ISP is Telekom in Slovakia ANNEX B.
I still see the WAN interface down.
xDSLFwVersion: FwVer:5.12.12.0_A_A60901 HwVer:T14.F7_0.0
Line State: Down
Modulation: N/A
Annex Mode: N/A
Firmware version is VMG3625-T50B_5.50(ABPM.0)C0
I tried every possible configuration, but still unable to connect.
I also tried to change the Annex mode to Annex B in config.
Can you help me please?
Hello @Rudolf Torvenyi
I cannot find the user guide for this model, but looking at the datasheets at ftp://ftp.zyxel.com/VMG3625-T50B/datasheet/ and the VDSL information at https://en.wikipedia.org/wiki/VDSL under profiles, then I think that Annex B is already supported but called Plan 997.
What are the LEDs showing for DSL? Green or Orange?
- the ones for VMG3625-T20A are in the picture below.
If the DSL LED is off. then the DSL line might not be active at all or not connected by your ISP or cable not connected correctly.
If you get a blinking DSL led then the VDSL line is being initialised.
I hope that this is helpful.
Merry Christmas and a Happy New Year.
Tony0 -
You probably need help from your ISP, but you could try enabling all the VDSL Profiles under Broadband > Advanced, which could look like this picture below in the GUI of your router.
but the LEDs could tell you things as well.
Merry Christmas and Happy New Year.
Tony0 -
Welcome to our directory of Internet Service Providers in Slovakia.The market competition has been able to force a number of the mergers as well as acquisitions in the recent years ... List of all internet access services registered in our base.
You mention that Telekom is your ISP in Slovakia and according to https://en.wikipedia.org/wiki/List_of_VDSL_and_VDSL2_deployments#Europe they have been supporting VDSL2 since 2013.
Tony0 -
Hello, thank you for your answers. The line is ADSL2. Now I have a different router (old Linksys ) on the line and this is working fine. With the new Zyxel router the DSL and internet LEDs are not blinking.
I have downloaded the config file and opened in text editor. I found in the release notes that the ANNEX is changeble with this setting X_ZYXEL_ADSL2_AnnexA_B. In the config I found that there is ANNEX A set. I have changed it to ANNEXB. (Because Telekom in Slovakia is AnnexB). But this didn't help
The cable comes from ISP to a passive SPLITTER. And from the splitter via R11 cable to the DSL port to the router.
Any other idea?
Maybe somehow to change th xDSLFwVersion: FwVer:5.12.12.0_A_A60901 HwVer:T14.F7_0.0 ? Maybe the letter "A" in the version means ANNEX A. Just guessing. But I didn't find any repository where can I change the xDSLFwVersion
than you and Merry Christmas and Happy New year0 -
You're welcome.
You seem to have the latest firmware according to ftp://ftp.zyxel.com/VMG3625-T50B/firmware/
Looking at the release notes, which you seem to have done, it has the setting for both Annex A and B as follows:
But if you have no flashing DSL leds then it seems like it is not coming up at all.
In the log file for my VMG1312=B10D, I get the following log entries for xDSLNov 9 21:20:23 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1Nov 9 21:33:08 user.info esmd: xDSL: PTM link down.Nov 9 21:33:10 daemon.info pppd: Connect time 94.1 minutes.Nov 9 21:33:10 daemon.info pppd: Sent 27349034 bytes, received 1782771042 bytes.Nov 9 21:33:10 daemon.warning pppd: Couldn't increase MTU to 1500Nov 9 21:33:10 daemon.warning pppd: Couldn't increase MRU to 1500Nov 9 21:35:05 user.info esmd: xDSL: link up, Connection Type: PTM, Speed: RX:50303 / TX:17237 (Kbps)
If you have got your Linksys working, then is there any config you can copy accross from that, such as the encapsulation (probably it should be set to PPPoA), and the VPI and VCI values for the ATM PVC configuration.
Tony0 -
its working! I have reset the router do default, changed the X_ZYXEL_ADSL2_AnnexA_B to AnnexB, set the correct PPPoE settings (I had these before correctly set) and it started to work.
Zyxel Support has replied that Annex B for ADSL does not work. But its working
Brilliant.
I am happy for you that it working now.
Time to save a backup of the configuration, so that you have it when you need it.
Tony0
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
