zyxel emg3425
Adam PP
Adam PP Posts: 1 image  Freshman Member
I can not delete 1 parental control or add any other parental controls?
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @Adam PP
    Do you have the EMG3425=Q10A or EMG3425-T50 router?
    There is some newer firmware dated January 2020 for T50 model, but it does not mention any bug fixes for parental controls.
    If you have a backup of your router's configuration, then you could do a factory reset to see if that gets rid of your issue, and then upload your configuration file (which hopefully might not give you the issue again)...
    Merry Christmas and Happy New Year.
    Tony
