Can't import certificates into XMG3927-B50A
kmr1962
Hi
I am having problems importing a custom CA and Local certificates into the XMG3927-B50A
When I select Import Certificate and choose the file to import the web interface just displays the "Working" animation but never comes back.
Can anyone provide any assistance/help/guidance please
For info
I have identified the issue
I have changed the IP address of the router and the web interface tries to upload the certificate to the default address (192.168.1.1) so fails
Reverting the address to 192.168.1.1 allows the certificates to be uploaded.1
Maybe this official (?) Zyxel guide will help you. Look at the steps under "Use Custom Signed Certificate":
https://mysupport.zyxel.com/hc/en-us/articles/360006916979--NSA-NAS-How-to-fix-certificate-error-on-browser-when-accessing-NAS-WebUI
zelgit
Thanks for responding
Unfortunately the process for uploading the certificates to the XMG3927-B50A is very different.
I believe that the issue is that the web interface is not actually even attempting to upload the certificate (ie the web interface is broken)
But additionally, I think that uploading the certificate would be in vane anyway as there also doesn't appear to be any way of setting the HTTPS web interface to use a custom certificate anyway, which is what I wanted to do.0 -
Oh I'm sorry bro, I totally missed that it was another product than a NAS. I see, but I'm not sure what to do in your situation. Maybe this official guide might be of interest to you:
https://support.zyxel.eu/hc/en-us/articles/360010685980-Import-a-Lets-Encrypt-certificate-to-the-USG
If not then I wish you the best, God bless.0 -
Hello @kmr1962
Is the local certificate you are trying to import signed by the Trusted CA you are trying to import?
If yes, then according to the user guide at ftp://ftp.zyxel.com/XMG3927-B50A/user_guide/ section 22.4 then you just need to add the CA certificate and the router will then trust any certificates signed by it.
You can only add 4 CA to the router according to the user guide.
Is the "Working" hangup occuring when you try to add the CA certificate to the Trusted CA list or when you try to add the Local Certificate?
Merry Christmas and Happy New Year.
Tony0 -
@tonygibbs16
Thanks for your reply
Unfortunately the import "hangs" when importing either the Trusted CA or Local Certificate
It looks as if there s no communication between the browser and the router after initiating the upload of either certificate.
I have tried this with the PC's Virus/Malware scanner disabled as well in case the issue was at the PC end.
When I get a chance I will have a look at the communication with wireshark and/or fiddler to see if I can see any issue with the communication.1 -
Hello @kmr1962
You're welcome.
It might be worth checking the file formats of the certificates as well. The local certificate with private key has to be in a PEM format file.
The CA certificates have to be in one of the following file formats:- Binary X.509
- PEM (base 64) encoded.
- Binary PKCS#7
- PEM (base 64) encoded PKCS#7
Tony0 -
@tonygibbs16
Just for info, I have tried all 4 formats
As well as CA certificates (Such as the Verisign Universal Root CA) exported from Windows 10
A Happy New Year to you too.
Kevin1 -
Thanks Kevin @kmr1962
Just for completeness, what firmware is your router running?
The latest in ftp://ftp.zyxel.com/XMG3927-B50A/firmware/ is 5.13(ABMT.0)C0 from early 2019.
- the release notes do not mention certificate issues.
So maybe Wireshark will show up something.
Tony0 -
That is the firmware I am running - "5.13(ABMT.0)C0"1
For info
- 588 USG FLEX H Series
- 477 News and Release
