Jason
Hi, I am using a ZYXEL PoE Switch, model GS1900-10HP, to test the power draw at a powered speaker.
Yes.Log into the web interface of your GS1900 switch.On the menu of the left, click on CONFIGURATIONThen click on PORTThen click on POEThis will take you to the POE Global View page.Make sure that "Consumption" is selected, and then,up and to the right, click on the word "Port".You will then be able to see how many milli-wattseach port is consuming.
Thank you for your answer. However, my main issue is that I need to monitor the power consumption and have a signal/trap on the switch in case it gets below a certain threshold. I know that the switch does not support MIB/SNMP, so I am looking for an alternative way , maybe a script?0
Hi @Anastasia ,
Welcome to Zyxel community!
We recommend you Zyxel NebulaFlex Switch GS1920-8HPv2.
It is a model that supports Nebula CC, and Nebula CC has elaborate chart of Power consumption and history.
In Switch summary report:
For every port detail:
There is also an advantage to use Nebula CC that you can monitor your Switch from anywhere you have Internet, not just limit to a private network.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
