Routing between NXC2500 and USG210
I would like to build a network with dynamic VLAN's based on 802.1X. Network topology looks like this
I have:
- USG210
- NXC2500
- GS1920-24Hv2
- 4x WAC6303D-S
On USG210 I have a few Site 2 Site to AWS and Azure clouds. The old network topology has no VLANS and all traffic from local networks was routed to AWS / Azure.
All addresses in security groups, ACLs, routes tables have IPs from VLAN10 (192.168.10.0./24). When I add NXC2500 between USG210 and GS1920 the routing stop working.
My first idea is to set up NAT Many 1:1 NAT for incoming traffic from VLAN10 and use the same IP range as the mapped IPs range.
Should it start working? Do you have other ideas how to solve the issue?
I have:
- USG210
- NXC2500
- GS1920-24Hv2
- 4x WAC6303D-S
Hi @Wojtas
If the NXC2500 is a bridge device between the USG210 and GS1920, you should add a VLAN10 interface on the NXC2500 with tag out.
The VLAN interface IP address should be released by USG210.
If you need the NXC2500 as the DHCP server, you should refer to the link which you reported before with the same topic.
https://businessforum.zyxel.com/discussion/5432/vlan-routing-between-nxc2500-and-usg210#latest
Joslyn0 -
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
