HELP! NSA325v2 RAID1 degraded!
doktor
doktor Posts: 14
image  Freshman Member
Hello, since the homeforum is being migrated I don't know if this is the correct place to repost an open question I have. Please advice if I should post it at another place. Anyway here is the original question and one additional step I took after the kind recommendation of user Mijzelf:
"I am trying to upgrade my current 2x2TB Hard disks to 2x8TB in RAID1.
So, first things first I made a backup of my 2TB files and then proceeded as follows:
1. Shutdown NSA325v2 (NAS for short).
2. Removed 2TB disk from tray 1 and inserted 8TB disk in tray 1.
3. Booted up and waited to see what happens.
4. NAS recognizes the new disk and reports array as degraded.
5. I select repair and wait...
6. After some hours, I see that the reconstruction process proceeds up to about 60% (last time I checked).
7. Next morning I check, reconstruction has stopped and array is still degraded.
8. I try to select repair but nothing happens.
So I decide to put the original 2TB disk back in tray 1, at least to restore the original array. I repeat the above steps having now removed the 8TB disk and having put the original, untouched 2TB back in tray 1. The NAS now reports this array as degraded and after reconstruction nothing happens and I can't ask it to try again.
So now I can't even go back to where I was in the start! I have a 2TB degraded array and I don't even understand why.
Please help!"
The additional step I took was to execute some command lines and here is the output:
cat /proc/mdstat
Personalities : [linear] [raid0] [raid1]
md0 : active raid1 sda2[2] sdb2[1]
      1952996792 blocks super 1.2 [2/1] [_U]
unused devices: <none>
mdadm --examine /dev/md0
mdadm: No md superblock detected on /dev/md0.
mdadm --examine /dev/sd[ab]2
/dev/sda2:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x2
     Array UUID : 4dccadb5:d1450afa:21a77618:e76638ad
           Name : NSA325-v2:0  (local to host NSA325-v2)
  Creation Time : Tue Sep 30 06:27:56 2014
     Raid Level : raid1
   Raid Devices : 2
 Avail Dev Size : 7813525504 (7451.56 GiB 8001.05 GB)
     Array Size : 1952996792 (1862.52 GiB 1999.87 GB)
  Used Dev Size : 1952996792 (1862.52 GiB 1999.87 GB)
    Data Offset : 2048 sectors
   Super Offset : 8 sectors
Recovery Offset : 2721861632 sectors
          State : clean
    Device UUID : 41eabffd:6dbe66b3:b2bcbcfc:e88151f2
    Update Time : Thu Jan  7 10:15:33 2021
       Checksum : 4b25b258 - correct
         Events : 2013919
   Device Role : Active device 0
   Array State : AA ('A' == active, '.' == missing)
/dev/sdb2:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid1
   Raid Devices : 2
 Avail Dev Size : 1952996928 (1862.52 GiB 1999.87 GB)
          State : clean
    Device UUID : af28ab52:2ec071ee:4d0b0550:6b745145
       Checksum : 2486c01e - correct
         Events : 2013919
   Device Role : Active device 1
fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 8001.5 GB, 8001563222016 bytes
255 heads, 63 sectors/track, 972801 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x00000000
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1               1      267350  2147483647+  ee  GPT
Disk /dev/sdb: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Disk identifier: 0x36035ebe
/dev/sdb1               1          64      514048+  83  Linux
/dev/sdb2              65      243201  1952997952+  20  Unknown
WARNING: GPT (GUID Partition Table) detected on '/dev/sdc'! The util fdisk doesn't support GPT. Use GNU Parted.
Note: sector size is 4096 (not 512)
Disk /dev/sdc: 4000.7 GB, 4000787030016 bytes
255 heads, 63 sectors/track, 60800 cylinders
Units = cylinders of 16065 * 4096 = 65802240 bytes
/dev/sdc1               1       60801  3907018580   ee  GPT
  • workinto
    workinto Posts: 44
    First Answer First Comment First Anniversary
    edited January 2021
    Which model of disk are you current using on 2TB and 8TB?
    If you have do the backup before, you can reset the device
  • Mijzelf
    Mijzelf Posts: 3,074
    image  Guru Member
    This data is generated at virtually the same moment? It's not consistent.
    /proc/mdadm shows the array as degraded, and AFAIK that is what the webinterface uses for the status. But the members itself think they are a healthy happy array.
          1952996792 blocks super 1.2 [2/⁠1] [_U]
    Did you already reboot after rebuilding the array?
    I made a mistake in my instructions,
    mdadm -⁠-⁠examine /⁠dev/⁠md0
    should be
    mdadm -⁠-⁠detail /⁠dev/⁠md0
    If a reboot doesn't work, can you give this info too?
  • doktor
    doktor Posts: 14
    Hello again and thanks for looking into this! In the meantime of the forum being transferred and inaccessible I decided after all to migrate to a Synology DS220j. So in the current condition I still have only one 2TB disk in the NSA325v2, since the 2x8TB are now in the Synology. Also, I am planning to decommission the NSA325v2 today, so I gave it another last try with the command you suggested, although only with one 2TB disk installed:
     mdadm --detail /dev/md0
    /dev/md0:
            Version : 1.2
         Raid Level : raid1
       Raid Devices : 2
      Total Devices : 1
        Persistence : Superblock is persistent
        Update Time : Thu Jan 21 09:06:30 2021
              State : clean, degraded
     Active Devices : 1
    Working Devices : 1
     Failed Devices : 0
      Spare Devices : 0
             Events : 2075073
        Number   Major   Minor   RaidDevice State
           0       0        0        0      removed
           1       8        2        1      active sync   /dev/sda2
    Before this I tried several reboots as you suggested and I was able to build the 2x8TB array, but only from scratch, that means not with the 2TB installed, but by removing the 2TB disks completely and installing the 2x8TB blank disks. That worked indeed, but it defied the purpose of being able to upgrade from an existing environment. Since I would have to manually copy my files from the backup to the newly created 2x8TB array it was just the same to me to upgrade to a new NAS (OK, I had to spend some money, but the Zyxel was outdated anyway...)
    So I would like to thank everybody, and especially Mijzelf for all of his wonderful support!
  • doktor
    doktor Posts: 14
    /dev/md0:
            Version : 1.2
         Raid Level : raid1
       Raid Devices : 2
      Total Devices : 1
     Active Devices : 1
    Working Devices : 1
     Failed Devices : 0
      Spare Devices : 0
             Events : 2075073
           0       0        0        0      removed
  • Mijzelf
    image  Guru Member
    should be
  • Mijzelf
    image  Guru Member
    Could it be this one?
