Zywll 310 VPN L2TP Connection - Can't see computers on network
When I connect to my VPN (Zywall 310) everything connects fine, I can ping local computers and devices on the network and I can access devices like a copier via it's web interface. However when I look at the network I don't see any of the remote local devices. I'm assuming because I can access them via IP the connection is fine but perhaps some sort of DNS setting or setup needs to be done so I can just see them under Network.
For the VPN connection in advance is Enable NetBIOS broadcast over IPSec checked?0
Hi @bpworker
If establishing L2TP VPN connection successfully you can navigate Web GUI path to check L2TP user connection status: MONITOR > VPN Monitor > L2TP over IPsec > L2TP_Remote_Users just like the following picture shows.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
