NSA320 public folder has gone missing
bobsf
Used to work just fine. At some point in the last few weeks, the public folders disappeared. I expect it was a Win10 update that broke it. Now itunes is lost. How can I get the public folder back to visible. I see it when I log in to the NSA device via web browser but it is invisible to the computer and hence to itunes.
#NAS_Oct_2018
#NAS_Oct_2018
That might be related to SMB1. Your 320 is quite old, and only supports SMB1.That is proven insecure (WannaCry used a vulnerability in SMB1), and Microsoft is phasing it out.You basically have 3 options:
- Ditch that NAS.
- Re-enable SMB1 in Windows
- Get SMB2/3 working on the NAS. For this there are 2 options:
- Install a different OS: Debian,Arch arm
- Install a newer SMB version on stock software using 3th party tools.
The link to installing Entware-ng is dead, but it all boils down to installing MetaRepository
Do you have an archive.org link for "Install a newer SMB version on stock software using 3th party tools"? zyxelforum.de seems to be down.0
Unfortunately not. Basically it's installing and enabling the zyxel-samba-replacement in Entware-ng.Enabling is setting the execute bit for the /opt/etc/init.d/ script/1
Thanks.
I also found this in Google Cache. http://webcache.googleusercontent.com/search?q=cache:dyiIrnWM3ZsJ:www.zyxelforum.de/viewtopic.php%3Ff%3D311%26t%3D11885
I think it is a copy of the same page
Has anyone a full walkthrough to achieve the Zyxel Samba Replacement on a NSA310? Some links to instructions are down. Any help appreciated
Hello everybody. I have downloaded the zyxel-samba-replacement (zyxel-samba-replacement_3.6.25_all.ipk) posted by Mijzelf, but no one of the other links for instructions work. How to install the replacement on my NSA320 ? Any help appreciated.
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
